Double switch for thermostat
Krystiann
I need some solution which can be "guard" of thermostat. I want to plug double switch to my thermostat (which controls temperature  my electric underfloor heating) when temperature is too high double switch will disabling the thermostat.
I read double switch can handle resistance  6A. Do you think it be safe?   What is your experience with double switch ?
If you want a switch which can turn on/off high power I would consider Heatit ZM Single Relay, the max load is 16A.
