Hey all,
Probably this is a question for some really experts outthere..
I have made a QA, which allows for user to set irrigation schedules..like start time, duration, days..etc..as it is not possible from HC3 panels..
User doesnt have acces from Yubii app to garden panel..
How can I achieve that a time variable, what is set in the QA by user..will then trigger a function in the same QA..
For example..user have set a scheduled watering in my App for Monday 6:00..This info is stored in QAs variables..
The QA has the functions which will start the watering, but i don't know how to start it at the time what has been set by the user..
Ohh..sorry..really confusing i think..but I hope some expert in Fibaro will have some answer, or at least some suggestion how to achieve this..
@Neo Andersson The QuickApp of @petrkl12 to create the HomeTable has a sceduling function:
Edited by SmartHomeEddy
you need in the loop function of your QA to check for "is the time set user between current and end of the day/schedule" or just "do we already reached start time", so in principle you have to compare each every minute if the stored value is equal to current time, and if so start the QA watering function. You need of course some interface for the user, to be able to change QA variables from BUI/App, and to save new values. If the user is you, or the user "know how to set time properly", yyou don't even need to check if the time set is properly formated ?
/monthly_2021_08/image.png.477f2ba41636c4ba06cf4345ec971416.png" />
    Thanks, this approach i knew..I just wanted to avoid using settimeout..
    If it was possible to create a brnd new scene from inside the QA, and when the user sets the time, it creates a scene with the corresponding time parameter. anyway thanks for the suggestion
    you don't need settimout, check this presence simulator, it does check time between, based on startTime and endTime values. So all you need is to hack some keypad together to allow user to enter values (as i did in the picure above), save these values in QA variable and to make use of it (with help of the between function from below Quick App) in your QuickApp.
    I think i expressed myself in a wrong way...i am sorry...You always need some kind of looping/polling/checking preocess, if you are checking when a certain time has come...theres no way to avoid it..I think even normal Fibaro block scenes are using it in the background when you select an exact time as a trigger..So my issue is coming from this: There are 3 watering relays, and I need to start one after the other..not together...First i need a function which will be constantly checking the time in a Loop. This is my first headache..Isn't this too high demand on the system, if we have forexample more settimeouts functions running all the day every second?
    Then we compare current and the scheduled time wether they matche, and if they do we need to start relays on by one..
    So the logic must be like this:
    function TimeCheckLoop()
          If current_time == schedule_time then
                  runIrrigation ()
           else
                 TimeCheckLoop()
    So this is the time checking logic...
    Then comes the run 1by1 problem.
    function runIrrigation()
    startRelay1()
    fibaro.setTimeout(15000, function()
                      stopRelay1()
                      startRelay2()
                                           stopRelay2()
                                           startRelay3()
                                                            stopRelay3()
                                                       end)
                                     end)
    end)
    This embedded style of setTimeout seems to me very nasty, and it doesnt even work...
    Is there any fault in my logic, or my logic is okay, only the code is bad?
                  runIrrigation ()
           else
                 TimeCheckLoop()
    startRelay1()
                      stopRelay1()
                      startRelay2()
                                           stopRelay2()
                                           startRelay3()
                                                            stopRelay3()
                                                       end)
                                     end)
    end)
    PI: Sorry...your example is too complex for my level..I don't uderstand how could you anyway continuosly compare two time values without being forced to run a Loop function which reads the current time then compares it...
