LUA Scene is not triggered? Problem with Linked Devices or Operator "anyValue"?
Hi all,
I am not sure if I just don't see the mistake, or if it's really a bug. With the following conditions, the scene is only triggered by the variables "TimeOfDay" and "Late", but not by profile or the Window sensor (ID: 453).
The only special thing is, that ID 453 is a Linked Device of several window sensors. I am using this type of conditions for several scenes (without linked devices), where it's working very well and stable. But in this scene it doesn't work. I've already deleted and recreated this scene. On the first day, the Trigger worked well for all conditions. But on the second day, everything was the same as described above (only the variables worked as a Trigger).
I already had the same issue with 5.070 for this scene.
Has anyone noticed something similar? Could it be that the operator "anyValue" for new scenes, which are created with 5.080, doesn't work properly with linked devices or profile?
Thank you very much in advance for any comments or advises.
