Fibaro Dimmer 2 - switching on - problem
fondoftri
I have a problem with the dimmer 2 module (FDG 212). I tried to assign a scene function to a key (parameter 28). After this time (I think), even after returning to setting this parameter to zero (scenes function inactive), I cannot turn the light on with the switch. I can turn it on from the application, I can turn the light off with the switch after turning it on in the application, but I cannot turn it on with the switch. I can not set the dimming level from the application level, it automatically switches to the maximum value. A screenshot is attached, asking for help.
