integration with node-red? Control/poll nodered from HC3?
Does anyone use node-red and control it with HC3?
is it possible to activate stuff in node-red with hc3 - get info from devices in node-red etc?
    @akatar - that seems to be the other way around.
    controlling fibaro products from node-red?
    @Symbiot78 Sorry, i do not use nr icm with hc3, only with homeseer (a bit, just playing around with it)
    Perhaps @10deror @haterhas a better link for this.
    • 1 year later...
    I do this on a HC2, with an mqtt server in between HC2 and node-red (mqtt and node-red server on same hardware (raspberry pi)). Send mqtt signal from hc2 to mqtt-server and have an mqtt-input node in node-red to pickup the signal (or other way around). Same could be done with a webserver in between (http call from hc2 to webserver, http-in node in node-red)
