So I've got 1 motion sensor and every now and then my scene stops working.
I then go to troubleshoot and the motion sensor is just GONE.
I have to add it again to the system.
It is not hidden or anything, I cant even bring it up if I try going to it through writing the link and ID.
ID_OF_MOTION_SENSOR
This is really troublesome because I wanted to deploy about 30 of them and I can't be going around adding it again and again and fixing the scene because it gets a new ID.
Which motion sensor are you writing about?
And wich gateway are you using
    The Fibaro motion sensor and HC2 atm.
    Do not use Fibaro productions
    it just best suggestion
    So which motion sensor do you guys recommend? Main priority is battery life and ofc that it works with HC2 and later HC3.
    Also would entertain the idea of a 230v motion sensor.
    All I really need is just motion, no fancy temperature or anything else. Just when movement is detected send packet.
    Edited by Weider
    Don’t pay too much attention to 10der ? He is a bit grumpy at Fibaro. The Fibaro motion sensor should do the job, but isn’t the cheapest one and yes, has also temperature, lux, etc. etc.
    I guess the problem is the pir, do you have another pir to test this?
    Unfortunatelly I have just this one atm for testing purposes.
    Also the battery drained to about 52ish % after about 3 months. I’ve made sure to set everything so it rarely sends anything besides motion, very high treshold and long times. But it is in my office and probably triggera like 50 or more times per day.
    @Weider MS6 with latest fw. also works fine with USB power.
    if we are still talking about Z-WAVE.
    You recommend Multisensor 6 by Aeotec, @10der ?
    And now it's already Low battery wtf
    Edited by Weider
    it is possible to power it with usb power?
    @akatarall my ms6 (now it 8 devices) usb powered.
    i am totally move my home systems to ZigBee, but some devices what i can`t find zigbee analogue still living in HC3 as Z-wave and MS6 is sort of.
    Yes i know, the question was for @Weider
    Nah. The one I have now is battery only. But I’m getting a multi sensor 6 in a couple of days for testing. That one takes USB 5v. :)
