interesting observation - every day on 22:15 - 22:30
Hi All,
I have several QA's on my HC3 and one QA with name "run check", which control's that all other QA's works smoothly and updates with their own time intervals.
And if they miss to update their variable - pushes them to restart
firmware 5.080
And last week I notice, that every day between 22:15 and 22:30 lot's of QA stop updating, "run check" try push them to restart ( mostly with no success )
And after 22:30 everything works good, because Fibaro system restart all QA's again.
So, my question - what happens between 22:15 and 22:30 ?
Some cron tasks to free memory and it stops QA ?
@afendikov
could you share your “watch dog” QA?
I had similar problem - QAs reported error 500 but only HC restart helped.
Based on investigation by Fibaro they prepared special version of firmware for me and problem was solved. Now I have problem with HC3 freezing every 1-2 days (fibaro is working on it)
I have created special script in lua for my Netio sockets that controls if HC3 is alive and if not HC3 is restarted after 10 minutes (hard restart - socket is switch off and after 30s switch on)
Edited by petrkl12
