HC3 / From BLOCK to LUA > Code failing
I am completely new here (
), I read some posts but I did not find my solution.
I am trying to understand the concept of LUA and for that purpose, I made a scene using BLOCK, which is working perfectly fine.
I wanted to transform it to LUA, which works fine as well.
But as soon as I make ONE modification in the LUA (or adding a comment), it fails = scene do not output anything !!!
The code is the following.
CONDITiON (if a motion detector is seeing something it triggers my alarm):
ACTIONS
Any idea more than welcomed !
Thanks,
Fly
Is this what you meant to achieve?
    Yessss, wow, works like a charm !! What was my error ??? I am searching, I do not find... :-)
    I worked on it a lot, and I find also an alternative as follow:
    But either with my solution or yours, I experiment a lot of delay between the switch and the RED.
    And in addition, my daughter is playing on WiFi (tablet) to a game, she told me that each time I run a scene, it inserts a lot of lag/ping into her game.
    I suspect HUE for that, or Fibaro ?
    Apart the fact that the light switch on, and then the RED arrive VERY VERY LATE, I would like now to do LIGHT ON RED / LIGHT OFF / LIGHT ON RED / LIGHT OFF, etc...
    Is that possible ?
    Maybe, I am wondering if I am using the correct "Quick App" for my HUE ?
    Does it exist multiple app for it ?
    In particular, I would like one where I could easily choose the color on a slider. Does it exists ?
    Right now, I have this (not user friendly to choose my own color excepted to pick up one):
    @Fly The HUE bridge works with the Zigbee protocol. And on the 2.4ghz band.
    That might inerrupt with the Wifi on your doughters tablet if the device is also on the 2.4ghz.
    My advise would be, if possible set the tablet to use the 5ghz band. Maybe that helps.
