I cannot understand this update, obviously Fibaro is beyond me …. The update went fine, but now i see that in settings, general, access, alarms, rooms, zwave etc are no longer accessible. I can get to devices, scenes etc but most are now disabled. What happened??
How do you mean disabled, do you see error messages in your browser ?
Or show some pictures what you mean
    So this indeed seems to be browser related. After refreshing the browser, after the update, this problem went away.
    Nice, those simple solutions are the best ?
    Probably after page refresh you have been redirected to login page (your login session ended and because of that your interface was quite empty), am I right?
    @m.roszakWell I could browse devices, look at status etc, its just some things were not accessible. Strange behaviour I cant explain.
    The problem is the browser cache. After the update some Html stuff has changed.  So, when you still are using
    the same browser tab. With the same data in the cache, you will have problems.
    I always refresh/restart  everything after firmware/updates.
