Hello
please help me modify this QA to work properly.
The meter gives data in the form of Watt ... how to make fibaro correctly count the amount of energy consumed by the house?
Now the amount of power consumed is incorrect .. too much .... counted by fibaro in MW :)
I enclose the current QA ....
is there any chance for help?
I think it is more easy for others to react, to just put the source code in the post
I had a quick look, few things:
1. Don't use power interface with com.fibaro.energyMeter
2. For instant power (Watts) use com.fibaro.powerSensor device type for now (put Watts in property "value")
3. Fronius also gives on API summary kWh, put this in property "value" of com.fibaro.energyMeter then it will work property with the Energy Panel.
This was discussed more in:
Just take a look :)
Just for my knowledge, both solutions 2 and 3 or choose one of them?
(Also have a quickapp to update)
You can use both, com.fibaro.powerSensor only gives additional instant power graphs in Devices -> Settings.
If you do not need them - you can just put Watts in a label ;)
Energy Panel does not use Watts so this won't collide in any way if used properly (don't put Watts in property "value" of com.fibaro.energyMeter).
