Impossible local connection
from one week I discovered that I can't connect by ip address (or serial or find.fibaro) with my HC3 lite. I can connect and operate by remote access (Fibaro ID) but I can connect in local mode. I can't connect by my PC or by all my mobile devices. I set the HC with static IP.
Have you some ideas regarding the issues?
thanks in advances
4 answers to this question
Do you get a reply if you do a ping on the IP on your local network ?
    The ping response is timeout
    Request timeout for icmp_seq 0
    Request timeout for icmp_seq 1
    Request timeout for icmp_seq 2
    Request timeout for icmp_seq 3
    Request timeout for icmp_seq 4
    Request timeout for icmp_seq 5
    I can't understand because by  fibaro id all is ok, thanks
    I think your router might have problems giving out the IP you gave to your HC3L.
    Check your router, remove the static IP and set it to dhcp.
    did you change youre router?
