Hello
I think there is a problem with the smart implant and the DS18B20 temperature probes
Indeed the temperature probe is recognized as a 'multilevelsensor' and not as a 'temperaturesensor' in the child modules.
As a result, the temperature does not rise either in miniature in the tile of the room or is the probe in the smartphone application
Edited by flacon030
New Z-Wave Engine (3.0) or current one?
Some additional information about version of your Gateway and Smart Implant itself?
    current Z-wave version 4.33
    smart implant version 5.2
    Have you got in settings those two tabs?
    /monthly_2021_08/image.png.24716417b54908553ff134d1442169a5.png" />
    What version of Home Center software are you using?
    the version of my HC3 is 5.080.9
    No I don't have these two tabs in the Zwave panel
    Do you have an idea of the problem?
    This should work normally, I will try to reproduce on monday - if I won't be able to do so I will contact you on pm to take other steps.
    thanks No problem
    I was able to reproduce this one - external sensors (connected using 1-wire) are being added as generic multilevelSensors (not temperature or humidity sensors).
    Those are working ok but types are wrong (too generic).
    Issue reported and on "to do" list.
    Thanks for the report!
    Fixed in today's hotfix (5.080.20).
    • 4 weeks later...
    hi! is there already any solution for this issue?
    i´ve a fgbs-001 since a long time working perfect.
    since update from 5.070.42 to 5.080.20 none of the ds18b20 is working. also a downgrade of my homecenter 3.
    exclusion and reinclusion made noch change.
    Edited by cherrytree
    FGBS-001 - old binary sensor?
    There should not be any issue with them, I have tested those alongside FGBS-002 (Smart Implant) when we were fixing issue mentioned here.
    What version of the modules?
