Only receiving ‘Pressed2’ in HC3 Lua scene triggered by Double Switch 2
I was trying to get a scene working on single clicks from two different Double Switch 2 (FGS-223) units, but it wasn’t working, so I made a little test script (see below) to see if anything is happening at all. It turns out that no matter how many times I press a button (1, 2 or 3 times), it always shows as attribute ‘Pressed2’. The same happens for both switch units. Both have parameters 28 and 29 set to 7 (sending scene triggers on single, double and triple press). What could be going wrong here?
Declarations:
Actions (test script):
run soft reconfiguration, check if association is set (Endpoint 0, Group 1 to HC), set the 28 and 29, set 20 to 0 and try again
Edited by tinman
    Thank you tinman! It turned I forgot to change the switch type (parameter 20) for both units. Now it works.
