Device energydata do not get polled to energy panel
Hello
i installed a Heatit trmz3 thermometer with room sensor.
in device settings it seems to read the consumption but no data shows in the energy panel.
Also i see two new checkboxes under advanced settings global pooling and inerval polling, what is the difference.
device shows consumption but not total energy use
Energy panel
I will check it out on Monday, I may have an idea why this is happening but need to check it first.
    It is weird
    the checkbox in parameters was on, i then turn it of and on again , it then worked.
    Maybe it just showed the wrong checkbox setting after installation of the device.
    Ok, I know what happened.
    Energy panel uses deltas from the reports in time.
    So, first value in energy panel from specific device will be shown when report with new value (higher than previous one) will be received by the gateway.
