Set time Heatit Z-temp2
omarinho
I am having this problem that i just can't seem to fix. I was hoping that someone here would have a solution for me.
I am trying to change the configuration of my Z-Temp2 thermostat so that i can adjust the temperature on the physical interface of my thermostat for more then 2 hours.
Whenever i change the temperature and i have the climate schedule on it jumps back to the climate schedule after two hours. I figured out it was not possible to change the standard set time of 2 hours on the physical interface so i was hoping i could do this through a lua script.
These are the functions i was able to use in the block scene, but for some reason they dont work/respond to my calls. I might be using them in the wrong way though.
Is there anyone who has found a way to change the set time of the Z-Temp2 Thermostat through a script?
Hi, maybe I weird question towards your issue. I am struggling with the same configuration the only issue I have is visa versa. My system runs in schedule mode, when I change the heatit itself manually the temperature stays on and in want it to get back after x time to the schedule but I don’t know how..
any idea how your configuration is done? Maybe we can share settings since you want my “configuration”
Hi, i am interested how you went with this. I too have it jump back to the schedule after 2 hours. I would like it remain untill the schedule changes later.
Cheers
