The app is not loading when phone on wifi.
It's working on LTE.
See pic.
See pic.
Hello @Milan Takacs,
Could you provide more details:
- HC3 is connected via WiFi or ethernet?
- you are log in via administrator or shared user?
- you are connected to 2.4 or 5GHz network?
- you are connected via log in offline option or via FID?
- are you using any VPN app? Can you temporary turn off it?
Same problem here
It was working fine with the previous version, but upon updating to 1.13 the app will not connect to my HC2 via the WiFi LAN (administrator, 2.4 GHz, no VPN active).
I was able to workaround the problem by DISABLING 'Local Network' in the iOS settings for the app, which means it only operates in 'remote' mode (via Fibaro) and not directly on the LAN.
Try disabling the "use default" option when selecting the gateway in the app.
That worked. Thank you
mmmhh Aha
same here
Fibaro?????
This morning my app 1.12 wast loading either just flikkering:
HC3 is connected via WiFi or ethernet?>>>> WIFI
- you are log in via administrator or shared user? >>>>not logged in on HC3 in app as admin
- you are connected to 2.4 or 5GHz network? >>>5.4 GHz
- are you using any VPN app? Can you temporary turn off it?>>>nope
After uninstall 1.12 and install 1.13 App is working
What was the cause of malfunction?
//Sjakie
when having more than one HC (which is the problem for me), i have to select the same HC (or different one) from the list in the top - that's all, will get loaded immediately.
Yep, same here. But disabling the auto connect option fixes that.
    - HC3 ethernet
    - shared user
    - mobile is on 5Ghz (if available, auto managed)
    - login with FID
    - no VPN app enabled
    Fibaro>>>
    Also this version does not reflect the state of arming/ disarming
    Today 20:00 I came home App showed no arming
    Open house and entree door >>>ALARM!!!
    Very frustrating
    When it will be fixed?
    //Sjakie
    4 minutes ago, Sjakie said:
    Fibaro>>>
    Very frustrating
    //Sjakie
    Well. you have a Iphone maybe ?
    Yes I have 11 pro, You havve the same problem?
    //Sjakie
    //Sjakie
    No, but i see a pattern. Geo location, and wifi issues should be reviewed in the IOS code.
    Same here. But also disabling the auto connect option fixes the problem
    Geo location did not work two times today
    //Sjakie
    //Sjakie
    I have information that nothing has changed with geolocation since the two versions of the application.
    I will try to check it later.
    Worked for me as well - thanks
    Where do I see the "use default" option? I only see the name of the HC3 and the name of the HC2. Then I select one of them: voilá
    Settings >> gateway>> use as default
    • 1 month later...
    I’ve found I can connect using wifi and ‘Use Default gateway’ —> On, provided (while the app is trying to start on wifi), I tap on Settings, then select my Home Centre, it eventually loads.
    Very clunky ‘functionality’
