Neo Andersson 233
Hello there
I am struggling with Roller SHutter 3 module to get it work with remote control from Aeotec..or any else
The module has a bug probably, as the functionality is like following:
(I did make the associations as it should be)
1x click up button: it does nothing unless the blind is at the absolute closed position -- this is a bug. It shold work as it works in case of down button press
1x click and hold up button: blind is moving up, until i hold the button
1x click down button: it does go down wherever it is when i press the button
1x click and hold down button: blind is moving down, until i hold the button
So I cant use associations, therefore I decided to make it work through scenes, but i got stuck..
I want to achice a funtionality like this:
1x press UP button: it should start going up, wherever is the blind at the moment, and when I press UP button while its moving it should stop..
1x press and hold UP button: it should start the motion until i hold the button. If I release, then it should just stop.
the same for downwards
The problem is, I can't determine in scene, if the blind is in motion or not, so I can't make a LUA code for control the 1x press situation...
I tried also to change in parameters from momentary switch to toggle, but all the same...
There's no value, or property which could give me the blinds state (if they are moving or not) so I can't control the 1x press behaviour..
I tried also to hack it through energy or power consumtion, but it's also a deadway..because there is a minimum 30 sec reporting window for any state
change, so its not usable...
Is there any exepert or more experienced user, who can figure this out?
The associations are not working properly, so I need some scenes to get this work..
Thanks in advance
7 answers to this question
