How to turn off information notification in HC3
I have a problem with one nexa wall plugin that sends a lot of "power has been applied" to HC3 Notifications page
I have turned off notifications for the device but I still receive a notification every second minute
Removed the device and added it, still the same problem
  • 6 months later...
i have this problem also didi you find a solution?
  • 2 years later...
Did you try to suppress this device from the pooling list?
look at Avanced tab go to bottom parameter: Polling time interval  and set it to "Device exclude dfrom pooling"
This trick was working for AN179 which was doing the same type of message.
Now I still have this message but once when effectively the power of the device was reycled.
