HOT FIX 5.080.20 did you guys test this?
I did the update to
Result was a crash to auto repair after the update and after that endless reboot.
No problem overhere....update went smooth. Pretty bad that your homecenter is in a bootloop now.
Hope you can resolve this...?
    well, i ended with:
    factory reset master
    upgrade
    restore master
    factory reset slave
    upgrade
    change to new slave (it's new for the master controller after a factory reset)_
    restore master and slave
    pffffff
    my system went offline, had to hard poweroff after 20 minutes but it seems updated
    Updated with no issue, but humidity (aerQ) on Yubii IOS app main screen is gone :(
    yubii is smart, it proberbly thought you never looked at it
    Yubii hangs here since update on iOS. Send a big report in testing phase. Have to select home again in app and then it loads on local network. On cellular external it works.
    Hello, we were looking forward to fixing errors in the work of the master controller with the slave controller. As soon as we saw the update with a solution to our problems, we decided to upgrade to 5.080.20. Result the master controller has been updated. The secondary controller has become completely unavailable. Now we are eating urgently at the object to look at what is wrong. We are getting tired of the problems of working with interconnected controllers. Something went wrong again ??‍♂️
    You're testing the beta right? through testflight?
    I had the same.
    I uninstalled it.
    then installed it via appstore NOT testflight.
    Now it works smoothly..
    1 thing I haven't tested.. : before I always had it in darkmode.. I've left it in light mode....  it really really shouldn't be that.. but I'm not going to jinx it right now.
    Seems like there is an update to fix one issue and causes others.
    I am so glad I went back to my HC2 for the time being.
    I have 3 test devices hooked up to the my HC3 and this I will try and add some more just for testing until the new z Wave engine 3 is FULLY finished and not on any beta version. Who knows how long this will be, probably no one knowing Fibaro.
    The Smart implant/universal sensor issues are the main reason I moved away from the HC3 and I use a lot of them for security and none of them worked the way they should. I understand there is a hot fix to help out with issues but I want something stable, not not a child's attempt at releasing firmware and hoping all will be ok with minimal/no testing.
    Anyways, Rant over. Lets see what the future firmware releases bring.
    well, i ended with:
    upgrade
    restore master
    factory reset slave
    upgrade
    When you do the reinstall the app defaults to light mode only.
    Update went smooth.
    Retsrat hangs 10 minutes
    Hard power down and up restarted HC3 (hehehe)
    Its still running
    IO dont know who to blame but all added icons in the App are gone again.
    Need a real? fix.
    //Sjakie
    Same here with the app..
    Edited by Nyko
    5 hours ago, akatar said:
    ну, я закончил с:
    мастер сброса к заводским настройкам
    Обновить
    восстановить мастер
    раб сброса к заводским настройкам
    Обновить
    изменить на новое подчиненное устройство (это новое для главного контроллера после сброса настроек) _
    восстановить хозяина и подчиненного
    It seems that the secondary controller has been updated and is working. I had to physically restart the entire system several times.
    No problem with the update
