Hi I have some devices triggering during zwave init and some timers based on variable based on date values which are not setting probably the timezone during HC3 startup....
Is there an api to detect :
- Zwave during init
- HC3 during startup
Thank you
Gateway startup
For gateway startup, the interpretation of conditions fields is as follows:
  • type - takes value "se-start".
  • property - takes value "start".
  • value - takes value "true".
  • operator - takes one of these values:
    • "==" - are the values the same
    • "!=" - are the values different
  • isTrigger - is the condition also a trigger:
    • true - is a trigger (recommended)
    • false - is only a condition (default)
Examples:
Trigger on every startup.
1
2
3
4
5
6
7
    type = "se-start",
    property = "start",
    operator = "==",
    value = true,
    isTrigger = true
(c)
also you can periodically poll this endpoint
http://192.168.1.36/services/system/servicesStatus.php
where 192.168.1.36 - your HC3
  • Thanks 2
  • 3 weeks later...
    hi
    to be honest reading the servicestatus does not help ...
    The issue I have is :
    - I have a Secure SSSR303 boiler relay
    - Form time to time HC3 shows a message
      [ZWAVE]: Pthread Initialize
    [[ZWAVE]: Z-wave start
    - and the boiler relay turns on ...
    8 hours ago, vifefref45 said:
    hi
    OK
    try to reboot you hc3 and call periodically this endpoint
    14 hours ago, vifefref45 said:
    hi
    service status is good to check if the service is still running (there is anway watchdog, which will restart the service if it stopped/crashed) ...
    ... and as you can see, the watchdog is working. So it looks like you have another problem, the zwave service should not crash
    this is switch, which is capable of turing on/off with thermostate commands, so the question is if HC3 is sending that during zwave startup. If you don't use the Secure thermostate to turn it on/off, i would say, replace it with another module. You can check as well, if that switch is not assigned as thermostate in climate zones.
    Edited by tinman
    seems to be fixed after : factory reset of the SSR303.
    Once included back ... seems that it had a HVAC attached to it so it might be that this was included somewhere in a climate ( maybie )
    I keep you in sync with the conclusion after a few days of tests
    Works.
    Edited by vifefref45
    • 2 months later...
    after testing this I am quite sure that the device assignment was the issue - the HVAN assigned to the default room and the boiler switch assigned to a different room
