Satel Integra 64 outputs still not switchable from HC3 software version 5.080
The outputs in the Satel Integra 64 are still not switchable from HC3.
You can switch the icon on in HC3 but in Satel nothing happens.
The other problem that bo scenes could be activated from Satel is solved.
In HC2 i switched the outputs from the Integra with a scene whitout any problems.
Can this also be solved ?
Thanks ,
Leon van Velzen
  • 2 months later...
For me, version 5.082.15 (beta) is still not working.
The outputs, as you write, do not work despite the display that the action was performed correctly :(
In addition, he can see the ZONES, but once they return their status on a regular basis and sometimes not - generally support and documentation of this plugin are a massacre :(
    Latest firmware verion 5.090.17 the outputs of the integra64 are still not switchable from fibaro. In HC2 this works perfect but HC3 still problems. All other functions working great.
    Please , wil someone repair this.
    • 3 months later...
    Whow! Integration between Satel and HC3 works both ways.
    You can read state of switches and sensor and you can switch on/off INT-IORS switches.
    I'm impressed!
    Firmware 5.100
    Edited by PiotrTheGreat
