Bugs in linked master - slave controllers remaining in version 5.080.20
Hello, before the update to 5.080.20, we did not write about previously noticed errors in the operation of related controllers, while waiting for a stable version. Now we want to draw your attention to the following. All of the following applies to devices attached to the secondary controller.
1. It is not possible to change the category of the device at fibaro reley (only the relay was checked, it was not checked on others), after changing the device, always return to the category of lighting.
2. Changing the parameter 20 "switch type" in the relay from 2 (by default) to 1 after the controller reboots with a high probability returns the parameter to 2. At the same time, if you change it to 0, then the reset does not occur.
3. Associations are not sent correctly, we need to send a multi-channel association from the thermostat - to one of the channels of the fibaro two-channel relay - a single-channel command is always sent and will work out all the relay channels. Moreover, a similar association on the master controller works well and correctly.
While this is all that we have noticed, we will continue to check.
    4. It is not possible to supply the poling interval with the frequency you need. The device page refreshes too quickly and returns the toggle to non-polling mode.
    Most of mentioned issues are being analysed right now with plans for next release.
    I will keep you updated on the progress.
