Error with adding Heltun thermostat in version 5.080.20
Hello, we have found a bug in adding Heltun Z-Wave Fan Coil Thermostat. Before the controller software update, everything was ok. It is added as a strange humidity sensor with power readings.
    It used to be like this. And this happens only on a controller with software version 5.080.20 with a z-wave 2 engine. On z-wave 3 everything is ok, the thermostat looks and is controlled like a thermostat.
    We are on it.
    I have had the same issue, and had to revert back to previous working version.
    It seems that latest Fibaro update which is making upgrade of power consumption panels, make teh Heltun Remote (where power measurements are) to be recognised as humidity sensor. The problem was on my TPS05.
    I have contacted Fibaro and Heltun support on this. It doesn't seem clear who should do what to resolve the issue. So until there's an update to fix this on either supplier, I would stick with 5.070.
    Hello @m.roszak,
    do you have any info about that problem?
    I have some installations at my costumers with Heltun products in few weeks.
    Thanks!
    In 5.080 we have change one little thing with creating devices (without template) - this resulted in wrong creation of devices in some cases.
    This is resolved and will be available in next version (5.081).
    Great news!
    When will be available the next version?
    Can we have it in a fast HotFix?
    So that is why my Remotec (older one without template) shows as 2 temperature sensors and not as thermostat and temperature sensor. ?
    That change almost ruined Fibaro training I led on Wednesday when I wanted to show AC integration.
    Edited by jakub.jezek
    I have the same problem with TKB thermostats. They are all adding as 2 temperature sensors.
    The good people at Fibaro need to understand that thermostats are mission critical devices and not having control over heating is kind of important. These boxes are now becoming critical to homes and there needs to be a fast resolution to issues like this. Is there any update as to when .81 will be out?
    I hope very soon.
    Please rollback to previous version if this can't wait a week or two.
    15 hours ago, m.roszak said:
    I hope very soon.
    You are the best!
    Thanks the info!
    Which version will it work on and can you go back versions without affecting other things?
    On 9/22/2021 at 4:43 PM, m.roszak said:
    I hope very soon.
    @m.roszak have you got any fresh info about the update?
    I have some hanging system extension, and there is the heating season.
    The customers have no more patience. :(
    Next version is on closed beta stage, we are tweaking some things and it should be released later next week at the latest.
    Thanks the info.
    Now I can say something to the customers. :)
    Released right now ;)
