FamSetsaas 0
Hi Fibaro experts,
I'm trying to implement error handling for temporary errors in the main loop of a VD, but got stuck.
I've made a setError function, which sets an error icon, and sets the lblStatus text on the VD. Then I want to exit this instance of the main loop of the VD. I've tried fibaro:abort() in the error function, but this seems to permanently stop the VD execution.
This is about what I am trying to achieve
function setError(txt)
-- Set VD icon
-- Set lbl txt
fibaro:sleep(sleep_time)
<Exit this instance> <--- This is what I cannot figure out how to do. I want to exit this instance
-- Main code
<do something>
if status ==1 then setError()
<do something else>
if status == 2 then setError()
etc...
fibaro:sleep(sleep_time) <--- Restart the main loop after sleep_time
So whenever the setError() function is called (also within other functions), the main_loop of the VD should exit.
But the main loop shall be restarted again after one second, just as if execution when through to the bottom.
Any ideas?
