Dimmer 2 not working in app/web/scene
Several (all?) of my Fibaro dimmer 2 fgd212 has stoped working in the app/web. The thing that they have in common is that they are connected with a momentary switch, it's both led an halogen bulbs connected to the different switches.
When I control them through the switch s1/s2 they are working, but not when controlled through the app/web/scenes.
In the web it's possible to turn on/off and dim the light (green status, command sent), but nothing happens to the bulb. No power consumption is reported when they are turned on/off through the switch.
Has anyone an idea of what may be wrong?
My Dimmer 2 are still working fine on the HC3. But I don’t know what setup you are running.
    I am running a HC2 with firmware 4.620
    Could it be a zwave problem? I would start by checking that out, especially if one device was acting as a repeater to the other affected ones. There are some scenes on this forum to help you analyse the zwave traffic, or get a zniffer.
    I presume you've tried a reboot.
