mamy 5 wrzesnia 2021 czyli ponad 18 miesiecy od premiery HC3 i nadal VOIP nie działa.. gratulacje dla zespołu programistów Fibaro za olewanie jednej z flagowych funkcji centrlali oraz jej nabywców.  skoro jest jako pdstawowa usluga w menu to powinna działać... ale po co?
(This is the English part of the forum)
VOIP works properly.
just trying to connect to HC3 ASTERISK/FREEPBX ( via port 5060/tcp) between two sip clients.
all works like a charm. client with num 69 succ dialed to client 321.
69 client is windows MicroSIPPortable
/monthly_2021_09/image.png.b0c2a802c63d6fa3a047de2d678033bd.png" />
321 - android device
PS:
"mam" not "mamy" :) if you talking about yourself.
Edited by 10der
@10der
interessting, share your settings from both HC3 and MicroSIP please
tnx for @tinman
my HC3 was migrated from HC2.
sip accounts already here in HC3 database.
my fail.
    Mamy -  polish form about "time now"
    Are u try register new users and connect to HC3? every time... fail auth..
    I will push up this subject and let you know when I will know something.
    • 3 weeks later...
    I have an idea for a new TV spot .... FIBARO -  HOME CENTER 3 advertisement and information - we test on clients .. the fact that voip has not been working for almost 2 years .. so important that clients are trying to fix our incompetence! We won't do anything about it anyway!
    Next release resolves the issue, sorry for the delay.
