Problems updating Home Center Lite from 4.600 to 4.620
I have repeatedly tried to update Home Center Lite from 4,600 to 4,620, both from the mobile app and from the PC (Win10). When I try from the mobile app, an update apparently happens in a few seconds, and a message is given that 4,620 is installed. However, it is not, and after a few minutes the blue LED lights start flashing, and I do not get in touch with the HUB until I have restarted it.
When I try to update from my PC, it's usually not possible to enable download and update. A few times, however, it has been possible, and then the following has happened:
A new version is apparently being downloaded, and the update seems to be starting. At the same time, a message appears on the screen stating that it may take a few minutes to perform the update. Nothing more happens though, and when I investigate after a long time (up to 20-30 minutes) I see that the update process has stopped. The same thing happens with the HUB as after an update attempt from the mobile app.
One more thing: The LED light, which indicates that an update is available, flashes during periods, but it is off during other periods. I do not remember having observed this before.
With regards
Håkon Matre
  • 1 month later...
I have the same issue ! Tried tens of times - the same result.
Haakon, did you solved the problem ?
Could it help to downgrade to previous version (I have few compatible backups)
Thanks in advance.
George
Had exactly the same issues using LAN address...  have forwarded port on my router to use my public IP from the PC!!??? it worked w/o any problem.
Hope it helps
