Cannot remove ZWave devices in v4.620
I have an HC2 4.620 with a bunch of ZWave devices connected.
I cannot remove ZWave devices from the Add/Remove device screen. When I click on the Delete button, the viewport of the browser moves up to the top of the add/remove page but nothing else happens.
Happening both in MS Edge/Chrome and Firefox, I have cleared cookies etc. Also happens when I click Add.
Edited by Wigster
4 answers to this question
Guest Theo
Had the same experience today on my desktop Windows pc / Firefox. Then I tried the same with my iPad and saw the message "Try learning mode". So I put the Nodon Wall switch in pairing mode after starting the network delete procedure. That worked. Then I could add it again to the network with default settings.
Edited by Theo
poor writing style
I have same problem than Wigster and I have only PC system.
Does anyone solve this issue?
Many thanks for your help.
Roberto.
    I only managed to do it using the iOS app -- there the add/remove device feature worked perfectly.
    HI,
    I finally solved it switching HC2 off and on again, "like Windows"? and after that I can add/remove again.
    Thanks.
