Heatit Z-TRM3 on HC3 (slave) parameters reset
I have 3 HC3, one master and two slaves.
On one of the slaves, I have about 12 Heatit Z-TRM3 thermostats.
1) Over the summer, I have them all off, using the climate panel. Sometime at midnight, they all turn on for no apparent reason. The climate panel does not have any actions at midnight that could trigger this. Has anyone else seen this behavior?
2) From time to time the parameters reset on the thermostats. This means that some of them will start heating and not stop, since I use "A2F", external room sensor and floor sensor. Default is just "A", internal temperature sensor. The thermostat it self is not in the room that is being heated in the bathrooms, hence it will never get warm enough. Has anyone else seen this behavior?
I was thinking about a work around to at least find out when it happens, but I am not sure if it is possible to get parameters with Lua. Anyone knows how to get that? If I can get notification that the parameters change, I can handle it, until I find a real solution.
Great to hear if anyone else has any experience with this?
Peter
ad1)
Have you seen on event panel if the system send the action for the device (if this is system issue then those should be visible there) or only report with new state?
ad2)
Probably if parameters (Configuration I assume?) reset themselves on the device gateway is not aware of it - 99% devicess on the market does not report parameters change in unsolicited report.
You will need to cyclically poll whole configuration from the device to make Gateway aware of the change, this will have major impact on network performance during the procedure.
If you would like to try this let me know - I will past you a solution in Lua to poll the configuration automatically, as for parameters value - current values (known by gateway) are stored in property "parameters" on parent device.
    On 9/10/2021 at 10:59 AM, m.roszak said:
    ad1)
    ad2)
    1) I can see in the console:
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 21, value = 100
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 20, value = 60
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 18, value = 50
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 14, value = 10
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 13, value = 1
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 6, value = 270
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 2, value = 4
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 20, value = 90
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 18, value = 60
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 14, value = 50
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 13, value = 0
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 6, value = 400
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 2, value = 1
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 17, value = 100
    [11.09.2021] [12:20:11] [TRACE] [ZWAVE]: ID 977: Set parameter 16, value = 100
    All I see in the history panel for this device at this time is:
    2) The "set parameter" in the console, means it is the controller resetting the parameters, or I am wrong?
    Can I access this data using Lua?
    @m.roszak Are you able to help with above mention issues/questions?
    As for the logs - it means that controller sets this parameters, normally this needs user interaction.
    Is there a possibility that you have a script which does it?
    As for getting parameters in lua - yes, without a problem. Examples below:
    this prints all parameters from a specific device.
    @m.roszak I have been doing a bit of monitoring. This issue is actually not isolated to the Heatit thermostats, but also apply to Fibaro Flood Sensors (and probably more).
    It looks like that when z-wave restarts, then default parameters are randomly pushed to one or more devices on the slave.
    This is rather annoying, since it means that all devices on my slaves are at risk. How should we go about solving this?
    even if you set to not use template?
    @Pete123, when slave restarts or master? Or both?
    I have a problem reproducing this one.
    Hello, this problem with random receiving parameters on the slave controller was still in 5.070. We wrote about this bug in support, and also in the thread
    point 2. This problem remains and it greatly interferes with the normal operation of the system.
    We will take a closer look into it.
    We have fixed a lot of issues with GC recently, I will let you know if I reproduce this.
    @m.roszak If you have any issues reproducing the issue, please let me know and I will work on a method to provoke the issue.
    We have tested this on upcoming version with a lot of fixes related to Gateway Connection and we did not reproduce this.
    If you will find a way to do so please share it.
    It is possible that this is just fixed by other changes.
    @m.roszak I hope you are right. From my point of view it is easy to reproduce. Just reboot the HC3 slave and master, then at least some devices will have reset parameters.
    I will test it as soon as it is released. When do you expect that to be?
    It should be released later next week at the latest.
    As for the issue, I have found something which in some special conditions may cause this problem but still did not reproduced this on newest package.
    This "thing" is not as easy to be corrected (and won't be in next version) but I hope that other changes are likely to reduce the occurrence of your problem.
    Look forward to it. Any improvement will be welcome.
