I have three already connected flood sensors  fgbhfs-101
I am trying to connect to more and they will not be found on the system
Have tried to do a reset on both of them and I do not see any yellow lights after pressing three times only a green followed by red
  1. First question is it possible to connect more than three flood sensors?
  2. Is my problem that these devices are not resetting properly?
  3. How do I do a proper reset on this model device?
Thanks in advance
To which system are you trying to connect?
@jssmarathon first check if you have the correct sensors, there are homekit and zwave sensors
fgbhfs-101 are for Homekit
Edited by SmartHomeEddy
    Dear people who answered
    you are so right, I had purchased some before on Amazon just did a quick search for the new ones and the first thing that came up was the ones for home kit so I bought them
    What a waste of time trying to figure it out but I'm so glad I posted here and you folks responded.  I have ordered the correct ones for smart things and am sending the home kit ones back
    Thank you so much
    You are not the first one mixing them up ?
    Good luck with your new set
