dear @m.roszakcan you ask you QA's make a simple regression testing if some code change something.
http://192.168.1.36/api/devices/ 2371
/monthly_2021_09/image.png.0af6a7eee13feab023cca3e19688942a.png" />
delete 2371
ask
http://192.168.1.36/api/devices/2371
voila!
the same from UI.
delete button
warning
yes
deleted.
F5
device appear again!
NB: I am talking about child device(s)
I think that this is impossible to delete child device from QA - as designed.
It should be  better handled with correct http response.
I will put it in the backlog.
    you can’t believe me but it worked a year ago (AFAIR) ;)
    ehm, from BUI or Swagger? no issues for me to delete child devices from BUI.
    I will consult with developers and determine how we proceed.
    Removing childs without parent seems wrong for me -
    Why I should not believe you?
    If you said that it was working it was working ;)
    I can confirm I was able to delete child devices from graphical user interface about a year ago when I made some tests.
    I did not tried recently though.
    Edited by lazer
    yes I know u can!
    root@hc3:/home/tinman# rm -rf /
    4 hours ago, 10der said:
    yes I know u can!
    no joke, no matter if try from BUI to delete child, or from Swagger with device delete, it works, nothing after STRG+F5, nor over/api/devid,
    no matter f i try with official or inofficial device types
    Tested with HC3 and Yubii, both on ZW3 engine ... let me test with zw2 ...
    EDIT: no issues with zw2 HC3 as well, hmm
    Edited by tinman
    • 2 months later...
    I am using a "com.fibaro.philipsHue" device, after deleting a bulb on the Hue application, I cannot delete it on the HC3. I get an alert message stating that all philips Hue bulbs will be removed. If I confirm the deletion, the app will disappear from the list, but if I refresh the browser page, the device will reappear.
    Could you tell me if this is normal behavior or if it is a bug and if a fix is planned.
    I tried using the swager, but I get error 202 with the following message:
    cache-control: no-cacheno-store
      connection: keep-alive
      content-type: application / json; charset = UTF-8
      date: Sun28 Nov 2021 00:03:34 GMT
      server: nginx
      transfer-encoding: Identity
    Edited by MAM78
