I'd like to share my custom doorbell which uses my security camera and wall tablet.
I already had a security camera at the front door. I also had a wall tablet and a standard doorbell. So I had an idea to connect them each other.
To make smart my legacy doorbell I had to use z-wave module. I couldn't use standard switch module in the switch box because of the low temperature outside. I have 3-wire cable and 1 core wasn't used. So I could put a z-wave module inside the doorbell box.
The smollest 230V z-wave module I could find was a Mini Dimmer Qubino.
The flow:
Doorbell -> Mini Dimmer -> Fibaro Home Center -> Tasker Android -> TinyCam Pro
Tasker runs TinyCam app for 40 s., then closes it and runs my default Fully Kiosk Browser app with DAKboard.
My installation:
  • Please login or register to see this link.
    I don't use Wireless Charging. I cut it and connect with USB cable. I use it only to have a nice and small plug.
    Tasker plugins: Tasker Network Event Server, AutoInput
  • Fully Kiosk Browser app as
    launcher
    Used as photo frame with daily weather forecast
  • Please login or register to see this attachment.
Some pictures:
  • 4 months later...
@szmyk do you have a lua scene for HC3 please?
    @michal_pu no, I don't.
    Nice setup with a "classic" doorbell ???
    What kind of push button do you use for the ringer outside..?
    Classic bell switch with spring.
    /monthly_2022_02/99f5a92a31b78d6501ecad09ee057609.png.c89a0afcd4acfd2f560f25d69dbd4b6a.png" />
    Edited by szmyk
