Window/Door sensor
Is there a way to add/remove the sensor when installed?
I have the first version where the button is located at the bottom (by the way not so clever solution ;-)) and now after long time without battery and battery exchange I cannot add it to the system.
I see light blinking when installing new battery but then I was trying to press 3 times the button (microswitch)  I can see inside but no success.
Is there a way to do it without removing it? I was put with some very good quality 3M tape and I am afraid to remove by force not to leave permanent signs on the window.
Janusz
