Elibri 0
I connected RGBW strip to RGBW Controller 2, 12v LED adapter, wall button and socket (photo
). When using button the strip goes white on and off. All works fine. But when I try to use it through Settings > Devices > RGBW Controller 2 settings all works fine, however normal wall switch does not work after that. Controlled needs reboot then button works again.Can't I use two ways to control RGBW strip at the same time?
My idea was to use it as a white light with a button, but set it to some colored light while watching movies or use it in the scenes as alarm.
6 answers to this question
