Hello dear Fibaro community!
As you know I'm working hard on
Currently I'm finishing Advanced Lighting Control (ALC) that will be much more advanced and simpler to setup and use than Very Smart Lights (VSL) and hopefully support more lighting devices. That is where I need your help.
WHAT I HAVE
At the moment I have support for following light types or devices that can control lights:
  1. Fibaro relay modules of all types and versions
  2. Fibaro Walli Switch
  3. Fibaro Walli Socket
  4. Fibaro Walli Dimmer
  5. Qubino 16A wall plug
  6. Neo CoolCam wall plug
  7. Fibaro Dimmer 1 & 2
  8. Fibaro RGBW modules
  9. Aeotec LED bulb 6 Multi-color
  10. Philips HUE v2 for bulb types: Ambience Color, Ambience White, Dimmable and wall plug
  11. Combee 2 Zigbee USB gateway with HUE bulbs
  12. Nanoleaf Aurora, Canvas and Shapes panels
  13. LIFX color and dimmable bulbs
  14. Twinkly LED (not supported latest firmware update yet)
WHAT I NEED
  1. Z-WAVE DEVICES - I need JSON data for other producers of z-wave modules that can control lights that can be obtained from HC2 document page with link in browser: http://<YOUR_HC2_IP>/docs/#!/devices/getDevice. I need from this JSON "type" and "baseType" and "actions": {} part So I can make sure that all devices will be properly recognized and controlled.
  2. OTHER LIGHT TYPES - Any other type of lights that are integrated to HC2 with virtual devices. If you have working VD then please share this VD and I can make it compatible with UHAS. If you have other type of lights, but still not integrated with HC2 let me know so I can look for solution with your help.
NOTE - UHAS will be ported to HC3 and if you have HC3 with some interesting devices you can also help!
Thank you in advance for your help! ❤️
Edited by Sankotronic
Added devices that I get information needed
  • Like 4
Hi @Sankotronic
You already have the AutomationBridge Tasmota VD examples don't you?
/monthly_2021_09/image.png.5f4e137a4ca817c117effeda8b1760be.png" />  image.png.d0dee261dee59586ea2dba9a909660e9.png
    Hi @clowg
    ALC is completely different code than VSL so if you can export this two VD and send me on PM so I can prepare them for UHAS. I know that this VD's are added by automation bridge so they don't have any way to be found by UHAS without doing some additional coding.
    Thank you!
    Oehhhh, cant wait :)   Excellent stuff your doing there!
    Hi all,
    I have updated list of devices that I get (have) JSON data provided until now in my first post.
    THANK YOU!
    Write to me pm if you will need support
    I have this for you It's a multi color LEDstrip driver from Blebox
    It is working fine in HC3
    Edited by Bosman
    57 minutes ago, Bosman said:
    I have this for you It's a multi color LEDstrip driver from Blebox. It is working fine in HC3
    ehm, i don't remember giving you permission to post my QuickApps ..
    /monthly_2021_09/image.png.5dcae1be05a9b584fc464dc6f009bb5a.png" />
    The
    is open, pixelbox is derivation of wlightbox
    @BosmanHow can you have it for someone, when it's copyrighted software ???
    I ditn't know it was copyrighted, I bought it from a website. it is removed.
    @tinman, @Bosman ,
    I have deleted downloaded copyrighted QA and will not share it further.
