Can't (soft)reconfigure/include Aeotec TriSensor
HI, I have three TriSensors from Aeotec.
They've been included in HC3 about 1,5 year ago. Few days ago, one of them stopped responding because I unplugged Fibaro Wall Plug which was near TriSensor and probably it lost connection with the HC3.
Tried soft reconfiguration, full reconfiguration, hard reset of TriSensor, inclusion, but no luck.
Most often it fails and endup as "device not configured":
/monthly_2021_09/image.png.9eb3e830e8473a27bbe69cc3007c415c.png" />
Sometimes it looks like been added successfully but there is two light sensors instead of motion sensor:
I thought ? maybe one of sensors is broken...
But... I soft reconfigured another one (which was working properly), and... now I have two sensors which I cannot reinclude... ?
EDIT: HC3 version 5.080.20, old Z-Wave engine, inclusion in normal mode (not secure)
EDIT2: similar issue, other device:
Edited by dlizak
Fix is on its way - in next version moton sensor will be back :)
same issue over here. Also not able to change type at basis parameters. "fix is on its way" pff sure but when, can't add device which is very inconvenient !
Edited by ErikP
  • 4 months later...
Having the same issue with us as of now.
We are using Fibaro Home Centre 3 Version: 5.080.20.
Also did the same procedure mentioned above. But still showing the same result.
Is there anyone that resolved this issue?
Is there anyone update the gateway to the latest version and it worked?
Just want to make sure its safe before we do the version update for the gateway.
Will be a big help for us.
Thank you so much.
