Aeotec garage door controller settings
Hi!
Does anyone know the parameter settings for disabling the alarm for the garage door having been open for a long time? I often leave the garage door open when I work around the house but after a while the Aeotec device will start buzzing if I don't close the garage door and that feature doesn't work well for me. Thanks!
4 answers to this question
@Ole
    @akatar I tried that but I still get an annoying buzzing sound and flashes if the door is left open. Any idea how to disable that?
    No sorry, i don't own that device. I post the link to the manuel because most of the times the answer is there.
    You can try to sent this question to aeotec.
    Are you sure that you get this sound a while after the door has been left opened?
    I did not find anything similar in the manual.
    Also I have this device and cannot remember such a behavior.
    My settings are the default ones except two parameters:
    36 (1 Byte) is 5 and 41 (1 byte) is set to 15.
    I have no (disturbing) sound at all.
