Using node red to get Fibaro device status
Good Afternoon,
I wonder if anyone would be kind enough to point me in the right direction please.
I am using Node-Red to trigger a couple of Fibaro relays using the following call, Which works perfectly.
http://USERNAME:[email protected]:80/api/callAction?deviceID=134&name=turnOff
I also have a Fibaro door contact which I would like to call and get its current status ie ON/OFF.
Is this possible using a similar call as shown above?
moving forward I have used this request
 to which I get the response below
Having sent the requests while the door sensor was open and closed i cannot seem to see where the current status is located
Many thanks
Andrew
Edited by fogmajor
Update
When i use NodeRed for HC3  it wont work
Made a
inject
http request in nodered
METHOD=GET
url=http://user:password@IPHC3/api/callAction?deviceID=23&name=turnOff
Return= a parsed JSON object
What am i doing rong
Can you help me
Edited by Kage
It is important that the user account you use for the integration has assigned rights in HC3. Motna, you just skimmed it. If you try it under administrator account, the cause must be looked for elsewhere.
i reset HC3 and works now. Dont know what the problem can be!
