wrong value in a global variable for delayed scene
I have a command in a block scene that runs another scene. This command is delayed.
The second scene is conditional and runs if a global variable is set to On.
Now, while delay is executed I  change the value of the variable with a switch to prevent execution of the delayed part.
But the scene seems still seeing the old value and executed anyway. Do you know if it is possible to fix it?
Really appreciate your help! I also attach few pictures with examples, however they might seem convoluted.
Thank you
Edited by Proseccoman
When running a delayed action, it will just setup a timer and run when time is up. There is no re-check of if whatever caused the delayed action is still valid.
(block scene's delayed action is the poor cousin to QA's setTimeout)
What you can do is that your trigger logic sets a global variable to true when triggering and to false when "not triggering"/safe.
The delayed scene then checks this variable before running the action to see if it's still valid.
