Taking the plunge - Will Fibaro HC work for me?
2 hours ago, stylo2 said:
Thanks - needs to be something that is more maintainable in the future by others so will avoid a Linux server I think.
Okay, I think at the end of the line you limit yourself quite a bit in the possibilities. Perhaps you should look for it in the really professional corner.
Homey for example. I wouldn't choose that. I read too many problems about it, especially now that they go "cloud only" ... no not my choice.
Then there are a few left, they are all linux based. All linux based. So you need your own server, and install the software.
So, I think you better outsource the whole thing.
5 minutes ago, ppeterr said:
All linux based
With a small Raspberry Pi, it ain’t that much of a step, I have three running, next to my HC3.
Edited by SmartHomeEddy
Sure, I agree with you there. But it's still linux.
And if you are not already doing that as a hobby. And as he says it cannot be maintained by "others".
Then I think it is indeed not the right choice.
@stylo2
Edited by ppeterr
there are windows based ha software
These aren't somfy but are still a respected brand
Add a roller shutter 3 and its good to go as native zwave.
I have Unifi also, there is info on here about how to setup wifi presence (eg to create a welcome home scene when your phone connects to wifi)
Fibaro will meet all the requirements you listed (robust, no cloud etc).
As for wall switches, I found selection difficult but there are some options out there depending on your country.  To allow both automated and non automated devices, Look for a switch brand that does both "bell press" and push on-push off switches in the same style. Clipsal in Australia does a couple of styles.
Zwave will be useful for your thick walls, given it's repeater function.
You can integrate to your alarm system using a smart implant, for turning alarm on and off.
You've done a trial so you know how the system works...take the plunge!
    Yes I guess will probably go with Fibaro and maybe not even bother with blind integration at the moment. Thanks for all the suggestions.
    @stylo2 you can open a somfy remote and connect a smart implant to "push the buttons"
    Ahh OK will probably be back then in 6 months when we get the house built to see how I do that - maybe by then there will be new integration options to look forward to!
