Aeotec Door Window Sensor 7 - Strange behaviour when updating parameters on HC3
Added new Aeotec Door Window Sensor 7 to HC3
As there is obviously no Template availalbe I added the Parameters manually (21 parameters)
1. Although all were set, I just received a subset of the parameters
2. For some of the Parameters I receive a strange response:
[30.09.2021] [10:07:56] [TRACE] [ZWAVE]: ID 1114: Set parameter 21, value = 5
[30.09.2021] [10:08:04] [TRACE] [ZWAVE]: ID 1114: Received parameter 1 report, value = 0
For some parameters the values is coming back correctly, for others the system always responses with parameter 1
Any idea, why this happens?
    Found the reason for this.
    It seems that there are different versions available (ZWA008, ZWA011, ZWA012) which have different parameters-sets. Tilt-Sensor Sensitivity is changed in parameter 15. In the other version (Pro-version) in parameter 21. I choosed the wrong one.
    • 5 weeks later...
    Can you make prints screen of parameters? I'm newbie and do not know how to do this
