Sonos VD to make scene
hi I'm searching on the forum for a Sonos VD so I can make a scene for Sonos. Can you tell where I can find the Sonos VD. I have found some Sonos VD but I can save them and do not understand what is the reason for that. My technical knowledge is not that good I just follow the manual. So if you have something that I can work with that would be great
I guess this one could work for you:
But it needs a bit of adjusting, you need to know your IP address of the Sonos you want to control. But there's 6 pages of questions and answers in there.
The other VD (Sonos API Player 1.0) is a lot better (I think) and easier to setup, but does need an extra device (raspberry PI) to talk to Sonos. You just need 1 VD for all Sonos devices while the other VD needs one per Sonos device.
    hi Emiel thanks for the links. Any idea why I cannot save the VD when I enter the tcp port and IP address
    don't know.... does your HC user has the proper rights?
