I would like 2 new features on the next hc3 firmware:
1) Three or more decimal places on the electricity tariff in the energy panel.
   My contract with the electricity company provides for a tariff of at least three decimal places after zero, not just two as is now accepted in the energy panel section.
   More decimals more precision.
2) in the Devices section, have the possibility to sort (with a click) the power section, in order to immediately see, at a glance, which are the devices with the most discharged battery and which will be the next to have the battery replaced.
I wouldn't hold your breath for these. There's apparently a large backlog of bug fixes and feature developments ahead of you. If you need this functionality, maybe you can use APIs to pull the data out of the HC3 and do the processing elsewhere?
Until then, you can for example use the battery check script:
no need to look at the battery percentages. The script works great.
