  • 2
HC3 LUA to add +1 to a standard variable. Create a counter in a scene.
I would like to be able to have a variable called for example:   counter1
When trigger happens (lets say ID 50 turns on) I want to read the current value of my Global Variable "counter1" as a number and then add numerical value "+1" to it.
Effectively every time the ID 50 turns on the variable counts up by 1.
I cant seem to get my head around the way HC3 does it in LUA
TIA
5 answers to this question
Did you ever workout how this is done as I'm struggling with a similar problem
I am not sure what you are trying to achieve but it sounds like something I am doing, I have a variable which i set to 12 and run a scene every 5 minutes to minus 1 which gives me a 1 hour timer, the same could be done in reverse and with different time scales.
here is my code that i am using hope it helps.
if DownstairsHeatingOverRideStateVariable == "false" then
                    fibaro.setGlobalVariable("heatingOverrideStateDownstairs", "true")
                    fibaro.setGlobalVariable("heatingOverrideDownstairs", "12")
                else
                    if DownstairsHeatingOverRideTimerVariable > 0 then
                        fibaro.setGlobalVariable("heatingOverrideDownstairs", tostring(DownstairsHeatingOverRideTimerVariable-1))
                    else
                        fibaro.setGlobalVariable("heatingOverrideStateDownstairs", "false")
                        fibaro.call(DownstairsHeating, "setHeatingThermostatSetpoint",dPanelSetpoint)
I am first getting the variable and converting it to a number as in local DownstairsHeatingOverRideTimerVariable = tonumber(fibaro.getGlobalVariable("heatingOverrideDownstairs"))
Edited by Jay Ess
Condition:
Action:
Last week I was also strubbeling with this. I found also on the web the solution and this works.
but, can you explain why the value in the GlobalVariable has 1 decimal (3,0)
How can I change the code so I write a number without no decimal.
Edited by twanve
