Hi everyone,
I have a big problem with a simple task: I have two bottom to control a light, for example the entrance and exit of a corridor.
The button has a LED that changes color if it is on or off and I have a HC3
I would like that if I turn on one of the two buttons, both are turned on.
I did it and it works. But if I quickly turn the button on and off I enter a loop and the light starts to turn on and off continuously.
to stop it I have to cut the power of my HC or turn off the scene.
I made many attempts to solve the problem but none worked (use of variables, single scene, multiple scenes, ...).
How should I do to make the desired configuration?
Thanks and best regards :)
PS I hope this is the correct category to put my problem
Maybe you can give more information about the switch  you are using.
You can put some switches or lamps in a configuration mode. By quickly flipping the switch a few times. The lamp then confirms the mode by flashing.
