Hi Everyone,
I would like to ask help.
So , In one location, the internet connection is solved by two microwave antennas. Between two antenna changes, the HC3 loses the net connection and the HC3 must be restarted.
I would like to check the net connection with Lua code if it does not than restart HC3.
Can anyone help me how to do this with Lua code?
Thank you in advance for your help.
192.168.1.36 you can change on 127.0.0.1 if you run LUA
response
Edited by 10der
Think about a solution to prevent multiple reboots
http://<HC-IP>/api/settings/network/connectivity
Response:
  • "internetConnectivity": true
Edited by cag014
    Thanks for the help.
    I tried, but it didn't work. Maybe I wrote something wrong.
    Can you help?
    DECLARATIONS (Conditions/Triggers)
      conditions = { {
          isTrigger = true,
          operator = "==",
          property = "state",
          type = "internetConnectivity",
          value = false
      operator = "all"
    • 3 months later...
    Can you help?
      conditions = { {
          isTrigger = true,
          operator = "==",
          property = "state",
          value = false
      operator = "all"
    @vskokosotthonHave you succeeded with the trigger InternetConnectivity conditions?
    Edited by Viorel
    • 1 year later...
    where to use that ??? I dont think directly in lua scene. Plz clarify @cag014
    nevermind, got it. Thankyou.
    You can also download this simple QA:
    It remembers when HC3 was last time rebooted and also time from last successful connection :-)
