FGBS-222 Changing Protection Command Class
I am using a Smart Insert FGBS-222 with an ISY994 hub.
I would like to use it to monitor the front and back door sensors. This I have working by changing Parameters 20 and 21 to 0 (normally closed triggers).
I would also like to use an output to control the humidifier on the furnace. Right now the outputs are tied to the inputs by default. According to the manual I need to change the Protection Command Class from State 0 to State 2.
Does anyone know how I go about doing this using an ISY994?
Thanks,
K-Bert
