msialk 1
I'm observing wired behaviour of my double switch. I connected it to two LED lights stripes. One of them works ok, the second one (connected to fibaro double switch in exactly the same way) is broken. It cannot be switched off by light switch on the wall as well as by fibaro system. In fibaro system I see that state is changed when I push the wall switch but the light is constantly is on. There is no way to turn the light off... What is more interesting after connecting all wires to the fibaro double switch everything works ok, I can switch the light on and off but then (after a couple of switches) it stops working and from that moment light is always on... I tried to switch S1 and S2, Q1 and Q2 with the second LED strip and in every configuration the behaviour is the same - one LED works ok, the second one at first works good but then stop working and light is constantly on.
