Fibaro 2 Gang 2 Way Switching Diagram for Double Switch 2
Does anyone have links to or could share wiring diagrams for  Double switch 2 2 way switching.  I can see diagrams for dimmer wiring on forums etc but not for the Switch 2.  I am not an electrician so maybe that I am missing the link to modify the dimmer 2 wiring diagrams to suit the switch 2.
Kenny
Have you seen the manual at
You can use a two way switching setup in place of the single switch shown. If you're not confident in doing that, I'd suggest getting an electrician to help.
