Device states (are lights on or not) won't update on UI or mobile app. Event panel shows everything right.
I have Fibaro Home Center 2 and dimmer 2:s and qubino flush dimmers, some other devices. Problem is that UI shows that there are lights on (and they are not). The Event Panel shows when light is dimmed or turn on/off but UI does not follow. I have no idea where to start searching the problem.
Does anyone have ideas for this?
Thanks!
4 answers to this question
Is it happens when you turn on/off the light manually?
Is the lifeline association with the controller properly configured? You can reconfigure the device, the dimmer 2 should have the right association with inclusion, with the qubino you may need to change it manually.
    This happens when lights are used from light switches (manually). What is lifeline association?
    @cag014,
    Why you ask:
    When I manually push a button who is connected to a dubble relays it will not always switch on or off.
    Do you know why?
    Push button is with light on if pressed on and off if off.
    If I follow light state button >>>on In app sometimes off! and counterwise
    //Sjakie
